Problem when building RTEMS optimized version
mikeci at acm.org
mikeci at acm.org
Wed Oct 15 15:47:59 UTC 2003
> Did you look in the config file that lives under make/custom/?
Yes, but it is not set there. There are couple of .m4 files where you can
find
-g. Is there a easy way to remove -g from optimized build? And second
question, who to avoid building samples each time when building libraries?
I tought that when you do configure without enabling tests this should be
enough. Still samples are built with enabling tests and without. Any
ideas?
Regards
Ivica
