How to provide main task?
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Mon Oct 20 10:30:34 UTC 2003
Ups,
should have checked that one too:
I think the following line is mising in your
configuration:
#define CONFIGURE_INIT
If it is missing, "confdefs.h" will not create a
configuration table. And then the only one
available is in "dummy.c".
wkr,
Thomas.
> Hello.
> This must be primitive, but I do not succeed to follow the structure of
> includes...
> I created C++ application with the following main.cpp content:
> #include "system.h"
> #include <stdio.h>
> #include <confdefs.h>
> #undef CONFIGURE_INIT
> #include <rtems.h>
> extern "C" {
> rtems_task Init(rtems_task_argument);
> rtems_task Init( rtems_task_argument ){
> printf( "\n*** My Main Init Task Entry. ***\n" );
> while(1);
> The system.h file contains:
> extern "C" {
> #include <bsp.h> /* for device driver prototypes */
> /* #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER */
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_MAXIMUM_SEMAPHORES 1
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_INIT_TASK_ENTRY_POINT Init
> #define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'C', 'T', 'O', 'R')
> #define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_TICKS_PER_TIMESLICE 1
> The problem is that linker says:
> powerpc-rtems-g++ -B/opt/rtems/powerpc-rtems/mybsp/ -specs bsp_specs \
> -qrtems -mcpu=860 -Dmpc860 -qrtems_debug -Wno-unused -ggdb -g \
> -Wall -ansi -fasm -qnolinkcmds -o op /opt/FDR/OP/Build/main.o \
> -T linkcmds -Xlinker -Map -Xlinker map.map
> /opt/rtems/rtems-bin/powerpc-rtems/FDR_GEN/lib/librtemscpu_g.a(dummy.o): In
> function `Init':
> /opt/rtems/rtems-src/cpukit/libmisc/dummy/dummy.c:23: multiple definition of
> `Init'
> /opt/FDR/OP/Build//main.o:/opt/FDR/OP/main.cpp:64: first defined here
> /opt/rtems/lib/gcc-lib/powerpc-rtems/3.2.2/../../../../powerpc-rtems/bin/ld:
> Warning: size of symbol `Init' changed from 40 to 32 in
> /opt/rtems/rtems-bin/powerpc-rtems/FDR_GEN/lib/librtemscpu_g.a(dummy.o)(.data+0x20):
> undefined reference to `main'
> Any help will be highly appreciated.
> leonp at plris dot com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
