ramdisk & flash
Tue Oct 21 12:40:18 UTC 2003
Francesco Poletti wrote:
> Hy I'm looking to the possibilities to have a very simple filesystems on the
> port of RTEMS on my simulation platform. There any kind of software driver
> for support something similar to a ramdisk? Or just a support to a flash?
The IMFS is a RAM based filesystem.  In the default configuration, you
get a "mini-IMFS" whihc only supports enough to have device nodes.
Add a #define for CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM and you will
have a RAM based filesystem with full POSIX semantics mounted as
> Thanks to all Francesco.
