Problem with gdb script
Brett Swimley
brett.swimley at aedinc.net
Thu Sep 4 20:29:30 UTC 2003
Hi all,
I'm using some of the gdb script commands that Joel had put together way
back when for examining task information. I'm using a patched version
of gdb 5.2.1 with support for the Linux BDM driver for the ColdFire.
Previously, I was using gdb 5.0 and had no problems.
I'm using rtems-ss-20030417 and the gcc-3.2.3 toolchain.
I'm trying to do the following with gdb:
p (Thread_Control *)_RTEMS_tasks_Information.local_table[0]
I get an error:
No symbol "Thread_Control" in current context.
gdb apparently doesn't like the cast.
Am I doing something wrong? Has there been some RTEMS restructuring
that would cause this error to occur?
I am not using any gdb "directory" directives. I did not use those
with my prior version of gdb and everything worked fine.
Any suggestions appreciated.
Regards,
Brett
Brett Swimley
Advanced Electronic Designs
ph: 406-585-8892 fax: 406-585-8893
