http demo in network-demos
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Thu Sep 18 05:09:52 UTC 2003
On Thu, Sep 18, 2003 at 06:47:23AM +0200, Ralf Corsepius wrote:
> All this sounds like code rott.
That's what I'd guess, but I thought the demos were built for each
snapshot.
> Which gcc are you using? Vanilla gcc-3.x probably won't work.
I'm using the gcc-3.2.3 RPM from ftp.rtems.com.
> Do the tests/samples compile? If yes, comparing the calls to gcc there
> and in your case probably will help.
They work fine. As far as I can tell, nothing else uses objcopy to
generate a linkable object (.o).
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20030918/8914c8f1/attachment.bin>
