Trouble initiating BSP
Bill Gatliff
bgat at billgatliff.com
Wed Sep 3 15:06:03 UTC 2003
Ralf:
Short answer: I'm now running RTEMS auto tools, and things now appear to
be as they should be. In particular, the bootstrap script runs without
issuing any errors, and my make all runs to completion.
/me thinks again about Debian...
But hey, at least I'm back to cranking on RTEMS code! :^)
b.g.
Ralf Corsepius wrote:
>On Wed, 2003-09-03 at 16:07, Bill Gatliff wrote:
>>Guys:
>>I'm starting on a MIPS-based BSP. Per some off-list suggestions, I'm
>>using the mongoosev CPU and genmongoosev BSP as a starting point. I'm
>>working with rtems-ss-20030703, and things aren't going well. I'm stuck
>>on the basic infrastructure changes needed to get the configure scripts
>>to recognize a new BSP and/or CPU, apparently.
>>As best I can, I've been following the BSP guide for this snapshot. I'm
>>clearly missing some required changes in the autoconf/automake stuff
>>(and perhaps elsewhere), and I'm thinking that part of the problem is
>>that I haven't edited any acinclude.m4 files.
>If you want to do it manually, you'd have to add your BSP to
>c/src/lib/libbsp/mips/acinclude.m4
>and run autoreconf afterwards.
>Alternatively, after having added your BSP to c/src/lib/libbsp/mips you
>could do this
>cd c/src/lib/libbsp/mips
>../../../../../bootstrap
>... which should have added your BSP to the configure-script
>>So, I've obviously unglued something! :^)
>I am seeing a lot of m4 quoting bugs.
>>Suggestions? I'll be happy to revise the BSP manual as necessary, once
>>I get over this hurdle and get my BSP up!
>As you mentioned to be using Debian, I would not be surprized to if you
>were using Debian's hacked-up autotools instead of RTEMS's autoconf and
>automake (These are *vanilla* autoconf-2.57 and *vanilla* automake >
>1.7.2 or 1.7.6)?
>Also, a common mistake is to append the path to the RTEMS tools to
>$PATH. Make sure these are picked up before any system tools (before
>/usr/bin and /usr/local/bin).
>i.e. with a standard RTEMS toolchain you'd have to
>export PATH=/opt/rtems/bin:$PATH
>Ralf
Bill Gatliff
Affordable GNU and Linux training and consulting services.
