Trouble initiating BSP
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Sep 3 14:32:13 UTC 2003
On Wed, 2003-09-03 at 16:07, Bill Gatliff wrote:
> Guys:
> I'm starting on a MIPS-based BSP. Per some off-list suggestions, I'm
> using the mongoosev CPU and genmongoosev BSP as a starting point. I'm
> working with rtems-ss-20030703, and things aren't going well. I'm stuck
> on the basic infrastructure changes needed to get the configure scripts
> to recognize a new BSP and/or CPU, apparently.
> My first step is to "clone" the genmongoosev BSP:
> $ cd rtems-ss-20030703/c/src/lib/libbsp/mips
> $ cp -R genmongoosev csb250
> Now I create a config file:
> $ cd rtems-ss-20030703/make/custom
> $ cp genmongoosev.cfg csb250.cfg
> ... and change RTEMS_BSP_FAMILY:
> RTEMS_BSP_FAMILY=csb250
> For now, I'm leaving RTEMS_CPU_MODEL at mongoosev, even though my board
> uses the Au1500. My strategy is to get all the build procedure changes
> right using the mongoosev system before I start adapting it to the
> Au1500. (I've confirmed that the genmongoosev BSP builds cleanly).
> With these changes--- and these changes only--- I get the following result:
> $ mkdir ~/build && cd ~/build
> $ ../rtems-ss-20030703/configure --target=mips-rtems
> --enable-rtemsbsp=csb250 \
> --enable-maintainer-mode 2>&1 | tee configure-log
> config.status: creating Makefile
> target architecture: mips.
> available BSPs: csb250.
> 'make all' will build the following BSPs: csb250.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> config.status: creating make/Makefile
> config.status: creating make/custom/Makefile
> $ make all install 2>&1 | tee make-log
> checking for RTEMS_BSP... csb250
> checking for make/custom/csb250.cfg... yes
> configure: error: Invalid BSP
> configure: error: /bin/sh
> '../../../../../../../rtems-ss-20030703/c/src/lib/libbsp/mips/configure'
> failed for mips
> '../../../../../../rtems-ss-20030703/c/src/lib/libbsp/configure' failed
> for lib/libbsp
> make[2]: *** [csb250] Error 1
> make[2]: Leaving directory `/home/bgat/bsp250-rtems/build/mips-rtems/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/bgat/bsp250-rtems/build/mips-rtems/c'
> make: *** [all-recursive] Error 1
> As best I can, I've been following the BSP guide for this snapshot. I'm
> clearly missing some required changes in the autoconf/automake stuff
> (and perhaps elsewhere), and I'm thinking that part of the problem is
> that I haven't edited any acinclude.m4 files.
If you want to do it manually, you'd have to add your BSP to
c/src/lib/libbsp/mips/acinclude.m4
and run autoreconf afterwards.
Alternatively, after having added your BSP to c/src/lib/libbsp/mips you
could do this
cd c/src/lib/libbsp/mips
../../../../../bootstrap
... which should have added your BSP to the configure-script
> But when I do so and run
> the bootstrap script, I get a ton of errors and then even the configure
> script won't work anymore:
> Add these lines to libbsp/mips/acinclude.m4:
> case "$bspdir" in
> * csb250 )
> AC_CONFIG_SUBDIRS([csb250]);;
> * genmongoosev )
> Run bootstrap (which, as far as I can tell, regenerates configure
> scripts and Makefile.ins):
> $ cd rtems-ss-20030303
> $ ./bootstrap
> cp: cannot create regular file `[$1]/install-sh': No such file or
> directory
> automake: configure.ac: installing `[$1]/install-sh'
> error while copying
> cp: cannot create regular file `[$1]/mkinstalldirs': No such file or
> directory
> automake: configure.ac: installing `[$1]/mkinstalldirs'
> error while copying
> cp: cannot create regular file `[$1]/missing': No such file or directory
> automake: configure.ac: installing `[$1]/missing'
> error while copying
> cp: cannot create regular file `[$1]/config.guess': No such file or
> directory
> automake: configure.ac: installing `[$1]/config.guess'
> error while copying
> cp: cannot create regular file `[$1]/config.sub': No such file or
> directory
> automake: configure.ac: installing `[$1]/config.sub'
> error while copying
> automake: Makefile.am: required file `./NEWS' not found
> automake: Makefile.am: required file `./AUTHORS' not found
> So, I've obviously unglued something! :^)
I am seeing a lot of m4 quoting bugs.
> Suggestions? I'll be happy to revise the BSP manual as necessary, once
> I get over this hurdle and get my BSP up!
As you mentioned to be using Debian, I would not be surprized to if you
were using Debian's hacked-up autotools instead of RTEMS's autoconf and
automake (These are *vanilla* autoconf-2.57 and *vanilla* automake >
1.7.2 or 1.7.6)?
Also, a common mistake is to append the path to the RTEMS tools to
$PATH. Make sure these are picked up before any system tools (before
/usr/bin and /usr/local/bin).
i.e. with a standard RTEMS toolchain you'd have to
export PATH=/opt/rtems/bin:$PATH
Ralf
