IDLE Task name error
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Sep 3 17:42:21 UTC 2003
Derick Hammond wrote:
> Hello all:
> I am looking for confirmation of a bug that I have found. I recently
> added a User Extension to my application to Display the task's name, id,
> priority, stack size, and stack start address for debugging purposes.
> I discovered that the IDLE task came back with garbage characters, but
> my initial task was reported fine.
> On further investigation I discovered the following mismatch:
> In file: ./rtems-4.6.0pre3/cpukit/score/src/threadcreateidle.c
> The global variable char * _Thread_Idle_name = "IDLE" is passed into the
> _Thread_Initialize procedure which is expecting a type of Object_Name,
> which results in the type mismatch.
> However, I believe the desired behavior can be found by defining
> _Thread_Idle_name as follows:
> const Object_Name _Thread_Idle_name = 0x49444C45 /* 'I', 'D', 'L',
> 'E' */
> If this is incorrect, or there is a better way to fix this, please let
> know, as I would like to submit this in a Bug report to RTEMS. If I
> haven't already done so by posting this message ;-)
Well email to the list doesn't consitute a bug report. :) Try the GNATS
database.
I think this is a real problem and don't see why this isn't
generating a warning in pre4. Go ahead and attach a patch to the PR
when you file it and it will get applied.
> Cheers,
> Derick
joel at OARcorp.com On-Line Applications Research
