Trouble initiating BSP
Bill Gatliff
bgat at billgatliff.com
Wed Sep 3 14:07:21 UTC 2003
Guys:
I'm starting on a MIPS-based BSP. Per some off-list suggestions, I'm
using the mongoosev CPU and genmongoosev BSP as a starting point. I'm
working with rtems-ss-20030703, and things aren't going well. I'm stuck
on the basic infrastructure changes needed to get the configure scripts
to recognize a new BSP and/or CPU, apparently.
My first step is to "clone" the genmongoosev BSP:
$ cd rtems-ss-20030703/c/src/lib/libbsp/mips
$ cp -R genmongoosev csb250
Now I create a config file:
$ cd rtems-ss-20030703/make/custom
$ cp genmongoosev.cfg csb250.cfg
... and change RTEMS_BSP_FAMILY:
RTEMS_BSP_FAMILY=csb250
For now, I'm leaving RTEMS_CPU_MODEL at mongoosev, even though my board
uses the Au1500. My strategy is to get all the build procedure changes
right using the mongoosev system before I start adapting it to the
Au1500. (I've confirmed that the genmongoosev BSP builds cleanly).
With these changes--- and these changes only--- I get the following result:
$ mkdir ~/build && cd ~/build
$ ../rtems-ss-20030703/configure --target=mips-rtems
--enable-rtemsbsp=csb250 \
--enable-maintainer-mode 2>&1 | tee configure-log
config.status: creating Makefile
target architecture: mips.
available BSPs: csb250.
'make all' will build the following BSPs: csb250.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating make/Makefile
config.status: creating make/custom/Makefile
$ make all install 2>&1 | tee make-log
checking for RTEMS_BSP... csb250
checking for make/custom/csb250.cfg... yes
configure: error: Invalid BSP
configure: error: /bin/sh
'../../../../../../../rtems-ss-20030703/c/src/lib/libbsp/mips/configure'
failed for mips
'../../../../../../rtems-ss-20030703/c/src/lib/libbsp/configure' failed
for lib/libbsp
make[2]: *** [csb250] Error 1
make[2]: Leaving directory `/home/bgat/bsp250-rtems/build/mips-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/bgat/bsp250-rtems/build/mips-rtems/c'
make: *** [all-recursive] Error 1
As best I can, I've been following the BSP guide for this snapshot. I'm
clearly missing some required changes in the autoconf/automake stuff
(and perhaps elsewhere), and I'm thinking that part of the problem is
that I haven't edited any acinclude.m4 files. But when I do so and run
the bootstrap script, I get a ton of errors and then even the configure
script won't work anymore:
Add these lines to libbsp/mips/acinclude.m4:
case "$bspdir" in
* csb250 )
AC_CONFIG_SUBDIRS([csb250]);;
* genmongoosev )
Run bootstrap (which, as far as I can tell, regenerates configure
scripts and Makefile.ins):
$ cd rtems-ss-20030303
$ ./bootstrap
cp: cannot create regular file `[$1]/install-sh': No such file or
directory
automake: configure.ac: installing `[$1]/install-sh'
error while copying
cp: cannot create regular file `[$1]/mkinstalldirs': No such file or
directory
automake: configure.ac: installing `[$1]/mkinstalldirs'
error while copying
cp: cannot create regular file `[$1]/missing': No such file or directory
automake: configure.ac: installing `[$1]/missing'
error while copying
cp: cannot create regular file `[$1]/config.guess': No such file or
directory
automake: configure.ac: installing `[$1]/config.guess'
error while copying
cp: cannot create regular file `[$1]/config.sub': No such file or
directory
automake: configure.ac: installing `[$1]/config.sub'
error while copying
automake: Makefile.am: required file `./NEWS' not found
automake: Makefile.am: required file `./AUTHORS' not found
(lots more errors omitted). Now the configure step gives me this:
$ cd build
checking for gmake... no
checking for make... make
checking for RTEMS Version... ss-20030703
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... mips-unknown-rtems
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets $(MAKE)... yes
../rtems-ss-20030703/configure: line 1640: foreign: command not found
checking for working aclocal... found
checking for working autoconf... found
(but otherwise appears to run to completion). And make all ends in this:
make[7]: Entering directory
`/home/bgat/bsp250-rtems/build/mips-rtems/c/csb250/lib/libcpu/mips/shared/cache'
/bin/sh
../../../../../../../../../rtems-ss-20030703/c/src/lib/libcpu/mips/[]/mkinstalldirs
../../../../../../../csb250/lib/include/libcpu
../../../../../../../../../rtems-ss-20030703/c/src/lib/libcpu/mips/[]/mkinstalldirs:
make[7]: *** [../../../../../../../csb250/lib/include/libcpu] Error 127
make[7]: Leaving directory
make[6]: *** [preinstall-recursive] Error 1
make[6]: Leaving directory
`/home/bgat/bsp250-rtems/build/mips-rtems/c/csb250/lib/libcpu/mips/shared'
make[5]: *** [preinstall-recursive] Error 1
make[5]: Leaving directory
`/home/bgat/bsp250-rtems/build/mips-rtems/c/csb250/lib/libcpu/mips'
make[4]: *** [preinstall-recursive] Error 1
make[4]: Leaving directory
`/home/bgat/bsp250-rtems/build/mips-rtems/c/csb250/lib/libcpu'
make[3]: *** [preinstall-recursive] Error 1
make[3]: Leaving directory
`/home/bgat/bsp250-rtems/build/mips-rtems/c/csb250'
So, I've obviously unglued something! :^)
Suggestions? I'll be happy to revise the BSP manual as necessary, once
I get over this hurdle and get my BSP up!
Thanks!
b.g.
Bill Gatliff
Embedded GNU, Linux, and other board support packages.
