Problem with gdb script
Brett Swimley brett.swimley at aedinc.net
Thu Sep 4 21:35:58 UTC 2003
Interestingly enough, if I do:
p (struct Thread_Control_struct  *)_RTEMS_tasks_Information.local_table[0]
instead of
p (Thread_Control *)_RTEMS_tasks_Information.local_table[0]
Things work fine!
It's an OK work around for me for now.
Regards,
Brett
Brett Swimley wrote:
> Thanks for the suggestion.  I tried it, and still no luck. :(
> Joel Sherrill wrote:
>> Sometimes "set lang c" has helped me when debugging Ada. Maybe gdb isn't
>> in the right language mode when you type this.
Brett Swimley
Advanced Electronic Designs
ph: 406-585-8892 fax: 406-585-8893
