Thanks for the suggestion. I tried it, and still no luck. :( Joel Sherrill wrote: > > Sometimes "set lang c" has helped me when debugging Ada. Maybe gdb isn't > in the right language mode when you type this. -- Brett Swimley Advanced Electronic Designs brett.swimley at aedinc.net ph: 406-585-8892 fax: 406-585-8893
