Problem with gdb script
Chris Johns cjohns at cybertec.com.au
Fri Sep 5 22:28:24 UTC 2003
Joel Sherrill wrote:
> Where should it go in CVS?  At the moment, I am leaning to
> scripts/gdb but I don't know.
It needs to be a location that we can have the files installed from.
> Way back when I tohught it would be nice to actually add empty
> shells of command and document them.  That way we had a plan
> which allowed people to add to this.
I suspect each command will come out of an itch someone has. If we have
a frame work then others can add to it. I will see what I come up with.
> No.  I am hoping ot keep it at the gdb macro level and not invoke
> any code on the target.  That seems more portable and safer.
Agreed, now ever GDB macros will run much slower. I suppose this is ok
for debugging.
> That makes one this week. :)
Sorry to disappoint, but I have changed my mind. I think the macros are
better in the RTEMS source code as they can changed based on a change in
RTEMS. Having to update GDB packages because of a script change does not
seem the correct thing to do.
  Chris Johns, cjohns at cybertec.com.au
