Where is the clock driver
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Sat Sep 6 18:56:36 UTC 2003
Hello Leon,
two things:
1. Try to define
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
before including "confdefs.h"
2. If you have your own driver table,
(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE is defined)
you need to add
CLOCK_DRIVER_TABLE_ENTRY
to your device table.
Hope this helps,
Thomas.
> Hello.
> I understand that this is stupid, but what can I do? All the day I try to
> solve this stupid problem, search all the RTEMS source tree with Source
> Navigator and do not find...
> I added the
> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> to system.h file, even recompiled everything, but still, the resulting
> application executable does not contain the existent clock driver, which I
> have in my BSP (derivative from the mpx8xx bsp).
> What must I for the driver to be attached!!??
> Thanks to all.
> leonp at plris dot com
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
