BSP for MIPS32 4KC
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Sep 10 16:39:27 UTC 2003
mikeci at acm.org wrote:
>>Ivica,
>>I am about to start a BSP for the AMD Au1500 which is MIPS32
>>and I wonder if you have any specific details on the context
>>and interrupt handling changes. If not, what makes you feel this
>>will be the case?
>>Thanks,
>>Michael
> Michael,
> Take look in $RTEMS_HOME/cpukit/score/cpu/mips. There you have cpu.c and
> cpu_asm.S. Edit cpu_asm.S and search for function _ISR_Handler. You will
> see that this function returns with:
> j k1
> rfe
> NOP
> .set reorder
> ENDFRAME(_ISR_Handler)
> This is incorrect for MIP32. rfe instruction is reserved for R3000 and not
> for MIP32.
> This is just one small example. All the files in this dierctory should be
> updated to support MIP32.
When someone has MIPS32 support they have the slightest faith
in, please submit a patch. If it only introduces new conditional
code and doesn't alter existing code, I am prone to merge it given
that there appear to be multiple testers.
If Greg Menke verifies that it doesn't break the Mongoose, then I
am prone to take more intrusive changes.
> Regards,
> Ivica
joel at OARcorp.com On-Line Applications Research
