BSP for MIPS32 4KC
gregory.menke at gsfc.nasa.gov
Wed Sep 10 17:09:55 UTC 2003
Joel Sherrill writes:
> mikeci at acm.org wrote:
> >>Ivica,
> >>I am about to start a BSP for the AMD Au1500 which is MIPS32
> >>and I wonder if you have any specific details on the context
> >>and interrupt handling changes. If not, what makes you feel this
> >>will be the case?
> >>Thanks,
> >>Michael
> > Michael,
> > Take look in $RTEMS_HOME/cpukit/score/cpu/mips. There you have cpu.c and
> > cpu_asm.S. Edit cpu_asm.S and search for function _ISR_Handler. You will
> > see that this function returns with:
> > j k1
> > rfe
> > NOP
> > .set reorder
> > ENDFRAME(_ISR_Handler)
> > This is incorrect for MIP32. rfe instruction is reserved for R3000 and not
> > for MIP32.
> > This is just one small example. All the files in this dierctory should be
> > updated to support MIP32.
> When someone has MIPS32 support they have the slightest faith
> in, please submit a patch. If it only introduces new conditional
> code and doesn't alter existing code, I am prone to merge it given
> that there appear to be multiple testers.
> If Greg Menke verifies that it doesn't break the Mongoose, then I
> am prone to take more intrusive changes.
Mea culpa- I've been sitting on mikeci's MIPS32 patch for a while,
I've been deeply busy on some other stuff. I'll have a look at it
today...
Gregm
