Newbie Solaris Question...
gregory.menke at gsfc.nasa.gov
Mon Sep 15 16:56:19 UTC 2003
Christopher Plummer writes:
> Yep, I've set the path as such. Not sure what I did, but I am not getting
> this error:
> /home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
> -B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
> -B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/ -isystem
> /home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
> -isystem /home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
> -B/home/kplummer/opt/rtems/sparc-rtems/bin/
> -B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
> /home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x assembler
> .../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
> xgcc: installation problem, cannot exec
> `/home/kplummer/opt/rtems/sparc-rtems/bin/as': Exec format error
> gmake[1]: *** [crti.o] Error 1
> gmake[1]: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build/gcc'
> gmake: *** [all-gcc] Error 2
> gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
> The 'as' that it is trying to use is the one from the
> sparc-rtems-binutils-2.13.2.1-2.t fi.
Can you invoke it by hand? ie; as --help. And do the rest of the
binutils work OK?
Gregm
