Newbie Solaris Question...
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Sep 15 17:04:04 UTC 2003
Christopher Plummer wrote:
> Yep, I've set the path as such. Not sure what I did, but I am not getting
> this error:
> /home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
> -B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
> -B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/ -isystem
> /home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
> -isystem /home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
> -B/home/kplummer/opt/rtems/sparc-rtems/bin/
> -B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
> /home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x assembler
> ../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
> xgcc: installation problem, cannot exec
> `/home/kplummer/opt/rtems/sparc-rtems/bin/as': Exec format error
> gmake[1]: *** [crti.o] Error 1
> gmake[1]: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build/gcc'
> gmake: *** [all-gcc] Error 2
> gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
> The 'as' that it is trying to use is the one from the
> sparc-rtems-binutils-2.13.2.1-2.t fi.
If you invoke "sparc-rtems-as --version", what happens?
--joel
> Kit
> Kit Plummer, Systems Engineer
> Operations Research and System Performance Dept.
> Raytheon Missile Systems
> 520-794-1552
> 520.794.0309 fax
> christopher_plummer at raytheon.com
> gregory.menke at gsfc.nasa.gov
> 09/15/03 10:16 AM
> To: "Christopher Plummer" <Christopher_Plummer at raytheon.com>
> cc: RTEMS Users <rtems-users at rtems.com>
> Subject: Newbie Solaris Question...
> Christopher Plummer writes:
> > Hey guys,
> > I am trying to get the RTEMS setup going on a Solaris box. I want to
> get
> > the UNIX/emulator kernel running locally to do some preliminary
> testing,
> > but am having trouble getting GCC to compile. Here's what I've done to
> > this point - I'm hoping someone can give the steps to get this thing
> > going...
> > Downloaded the sparc-rtems files for binutils, gcc, and c++ and
> unpacked
> > them. I've exported the PATH to include the new opt/rtems directory.
> > Next, I created a build directory, cded into into and ran the configure
> > command for GCC - which goes good. When I run gmake it errs during
> > compile with:
> > .../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
> > xgcc: installation problem, cannot exec `as': No such file or directory
> > Any ideas? Steps?
> Is the ~/opt/rtems/bin directory in your path?
> Gregm
joel at OARcorp.com On-Line Applications Research
