CONFIGURE_MAXIMUM_TASKS question
Harris, Andrew
Andrew.Harris at jhuapl.edu
Wed Sep 17 01:03:50 UTC 2003
> -----Original Message-----
> From: Angelo Fraietta [mailto:afraiett at bigpond.net.au]
> Sent: Tuesday, September 16, 2003 6:33 PM
> To: Harris, Andrew
> Cc: 'rtems-users at rtems.com'
> Subject: Re: CONFIGURE_MAXIMUM_TASKS question
> Have you defined
> CONFIGURE_EXTRA_TASK_STACKS
> I do this:
> #define CONFIGURE_EXTRA_TASK_STACKS
> (CONFIGURE_MAXIMUM_TASKS*10*RTEMS_MINIMUM_STACK_SIZE)
Hi Angelo,
Thanks for the response. I tried setting
CONFIGURE_EXTRA_TASK_STACKS to 64000, but that didn't help.
I'm also wondering what test sp02 is actually testing. I searched
around but was only able to find this page describing the test cases:
http://botzilla.free.fr/rtems/sptest_toc.html
Is there another document that describes what the test cases are
testing? Is this page accurate?
I took out parts of sp02 it and it starting working better. Slowly
putting parts back in it continued to work... with all three tasks. I
currently have removed the task_delete and task_(re)starts of tasks 1 and 3
in init.c, and the suspend then delete of task2 in task 1.
It seems there are alot of starts/suspends/deletes of tasks from
other tasks making the test complicated.
If anyone can explain what it's trying to test, I'd appreciate it.
thanks,
-andrew
