CONFIGURE_MAXIMUM_TASKS question
Angelo Fraietta afraiett at bigpond.net.au
Tue Sep 16 22:33:28 UTC 2003
Have you defined
CONFIGURE_EXTRA_TASK_STACKS
I do this:
#define CONFIGURE_EXTRA_TASK_STACKS
(CONFIGURE_MAXIMUM_TASKS*10*RTEMS_MINIMUM_STACK_SIZE)
Harris, Andrew wrote:
>Hi -
>	I'm trying to run test case sp02 and when I adjust the
>CONFIGURE_MAXIMUM_TASKS to something other (greater) than 4, wierd things
>happen.  I think I need the max tasks to be greater than 4 because I have
>tcp/ip support configured in.
>	I went into system.h in the sp02 directory and changed the
>CONFIGURE_MAXIMUM_TASKS field.  I'm using the mvme2307 BSP with an mvme2600
>board.  At first I thought the clockIsr/clock system was configured
>incorrectly, because with 5 tasks, TA2 never comes back after 1 minute.  But
>I think the BSP is setting things up correctly for my application because
>the clockIsr *is* triggering every 10ms.
>	Below is some test case 02 output.  Any help is appreciated.
>thanks,
>-andrew
>with CONFIGURE_MAXIMUM_TASKS = 5
>*** TEST 2 ***
>INIT - rtems_task_wake_after - yielding processor
>PREEMPT - rtems_task_delete - deleting self
>INIT - suspending TA2 while middle task on a ready chain
>TA2 - rtems_task_wake_after - sleep 1 minute
><and then nothing else happens (and I wait for > 1 minute)>
>with CONFIGURE_MAXIMUM_TASKS = 6
>*** TEST 2 ***
>TA3 - rtems_task_wake_after - sleep 5 seconds
>TA3 - rtems_task_delete - delete self
><and then nothing else happens>
>with CONFIGURE_MAXIMUM_TASKS = 7 or 8
>*** TEST 2 ***
>PREEMPT - rtems_task_delete - deleting selexception handler called for
>exception
> 7
>         Next PC or Address of fault = 1FDE334
>         Saved MSR = 8B032
>         R0 = 0
>         R1 = 1FD7670
>         R2 = 32250
>         R3 = 0
>         R4 = 0
>         R5 = 30000
>         R6 = 3032
>         R7 = 0
>         R8 = B032
>         R9 = 1FDE334
>         R10 = 0
>         R11 = 1FDEAB8
>         R12 = 11770
>         R13 = 357A4
>         R14 = 0
>         R15 = 0
>         R16 = 0
>         R17 = 0
>         R18 = 0
>         R19 = 0
>         R20 = 0
>         R21 = 0
>         R22 = 0
>         R23 = 0
>         R24 = 1
>         R25 = 1
>         R26 = 1FD76A0
>         R27 = 0
>         R28 = 1FD77D8
>         R29 = 0
>         R30 = 1FDF038
>         R31 = 1FDE374
>         CR = 84000048
>         CTR = 122A4
>         XER = 0
>         LR = 1FDE334
>         DAR = 0
>Stack Trace:
>  IP: 0x01FDE334, LR: 0x01FDE334
>unrecoverable exception!!! Push reset button
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
