Console_tbl setData and getData
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Sep 19 11:13:16 UTC 2003
Cedric Aubert wrote:
>Hi all,
>What setData and getData is use for ?
>I see it's use to read RX register and write TX
>Register
>but I don't understand why is here, we also have
>in the console_tbl the function to read and write
>characters in polled or interrupt mode.
>Can somebody explain it to me ?
The console_tbl has enough support functions to handle any type of
UART. Some make a distinction between control and data registers.
Some don't. THose that do not, ignore those fields.
>Thanks a lot
>PS : I think this function could be usefull to read
>and write signal to make a update to support
>TIOCMSET and TIOCMGET command. Could be done in a
>shared console.c, if everybody is ok I could make
>a patch for approbation.
I think the real HW driver will have to be intercept this and act upon
it as part of the ioctl() processing. I think it might require an addition
to the rtems_termios_callback OR (nicer) a new interpretation of some
piece of data in struct termios so setAttributes can work.
>Cedric
>AUBERT Cedric
>SDEL Controle Commande
>rue Nungesser & Coli
>44860 St Aignan de Grand Lieu
>E-mail : cedric_aubert at yahoo.fr
>Http : http://www.controle-commande.sdel.fr/
>__________________________________
>Do you Yahoo!?
>Yahoo! SiteBuilder - Free, easy-to-use web site design software
>http://sitebuilder.yahoo.com
