RTEMS on ARM
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Mon Apr 5 20:06:15 UTC 2004
On Mon, Apr 05, 2004 at 08:48:56AM -0300, Jairo Cavanus wrote:
> uC?s configuration:
> AT91FR4042: ARM 7 82Mhz, 512 KB Flash + 256 KB SRAM
> (http://www.atmel.com/dyn/products/product_card.asp?part_id=1983);
> AT91FR40162: ARM 7 82Mhz, 2 MB Flash + 256 KB SRAM
> (http://www.atmel.com/dyn/products/product_card.asp?part_id=1985);
> The one that I need besides the kernel is the basic TCP/IP + PPP...
> Will I need external Flash or SRAM?
That depends on your application, but for an Atmel AT91RM9200 (ARM9),
here's the sizes of the sample programs:
text data bss dec hex filename
113663 3020 47104 163787 27fcb arm-rtems/csb337/samples/base_sp.exe
88807 2968 39168 130943 1ff7f arm-rtems/csb337/samples/hello.exe
268135 8328 51200 327663 4ffef arm-rtems/csb337/samples/loopback.exe
88923 2968 39168 131059 1fff3 arm-rtems/csb337/samples/minimum.exe
177555 3428 48384 229367 37ff7 arm-rtems/csb337/samples/paranoia.exe
442929 16096 81408 540433 83f11 arm-rtems/csb337/samples/pppd.exe
115551 3020 45056 163627 27f2b arm-rtems/csb337/samples/ticker.exe
116943 2968 43776 163687 27f67 arm-rtems/csb337/samples/unlimited.exe
That indicates it would fit in your part, (maybe not the 512K one) but
executing out of flash, which is somewhat slower than sram.
Name: not available
Type: application/pgp-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040405/3662b54f/attachment.bin>
