How many Timers Can I Create???
Alex kbyte at iol.pt
Mon Apr 12 08:56:22 UTC 2004
Hi,
Does RTEMS has a confifured maximum number o timers it supports, or it naturally crashs when too much timers are created?
In an test I am doing I have the following:
#define CONFIGURE_MAXIMUM_POSIX_TIMERS 150
#define CONFIGURE_MAXIMUM_ 150
Then I have source code to create 100 timers, but when the program starts it hangs, even before starting sreating the first timer. The timers are created with the timer_create POSIX function.
If I configure maximum timers to 10 and if the source code only creates 10 timers everything is fine.
I searched in the limits.h but I found noting... :-(
Where could I find this kind of "system limits", for timers or for something else, like tasks, etc ???
Many thanks,
Alex
___________________________________________________________________________________________
IOL Flash. A net normal em versao acelerada.
Promocao: Ligue-se a Internet pelo IOL Flash e ganhe um Vale de €10 da Galp!
Saiba como: http://www.iol.pt/central_utilizador/iol_flash/promocao.php
