MPC555 port, and follow-up on PowerPC support
Felix Schill felix at syseng.anu.edu.au
Fri Apr 16 01:49:23 UTC 2004
Hi everyone,
> I came across this cleaning up my Inbox and it reminded
> me that I needed to announce that I have just merged
> David Querbach's BSP for the MPC555 based Intec
> Automation SS555 board.
Great, good news! Is anybody working on a BSP for the ec555-light board
by Wuerz-Electronics? That's the module I use (I think it's the smallest
mpc555 you can get), and I'll need a BSP for it. I probably can modify
one of the other 555-BSPs.
About the PowerPC-crosscompiler with Ada (my earlier mail):
Thank you, Ralf, for your help. I tried the 4.6 rpms from the link you
sent me, and they worked fine. Now I have to find/create/modify a BSP
for my board, and hopefully everything will be fine then.
> Hmm, I don't understand. Using the download helper you should have
> obtained rpms. Nevertheless you seem to be trying to build the
> toolchains manually. Why?
Well, yes, the download helper came up with rpms, but unfortunately all
the links to rpms it came up with were broken:
http://www.rtems.com/cgi-bin/dl-helper?version=4.6.0&target=powerpc&host=linuxRH73&want_toolsrc=on&want_cxx=on&want_ada=on
I tried to find rpms on the ftp server, but couldn't find them myself,
so I decided to try to build it from scratch (should've looked harder, I
guess...)
Maybe the download helper should be fixed, to avoid this in the future.
Thanks a lot again for your help, and your detailed description of the
current gnat-crosscompiler situation.
Felix
