execution stops at rtems_rate_monotonic_create() ?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 6 21:48:11 UTC 2004
kmedri kmedri wrote:
>> Is it possible that you are using an application Makefile based
>> upon hello world? If so, then it is linking in stubs for
>> optional managers. IThe rate monotonic manager is definitely
>> optional so every call would return not configured. It is
>> also quick possible that the clock manager is stubbed as well.
>> Look at the Makefile and the gcc command that is printed to
>> link the applciation.
> Thanks for the help. Here is the Makefile (I think initially based on
> the test_tasks example) that I am using along with a more appropriate
> manager statement for my program:
Well the big question now is .. did this fix it? :)
> # Makefile
> # RTEMS_MAKEFILE_PATH is set in an environment variable
> EXEC=bike.exe
> PGM=${ARCH}/$(EXEC)
> # optional managers required
> #MANAGERS=io
> #http://www.rtems.com/ml/rtems-users/2003/may/msg00025.html
> #however http://www.rtems.com/ml/rtems-users/2000/july/msg00095.html
> MANAGERS=all
> # C source names
> CSRCS = bike.c tasks.c port_sim.c
> COBJS_ = $(CSRCS:.c=.o)
> COBJS = $(COBJS_:%=${ARCH}/%)
> # C++ source names
> CXXSRCS =
> CXXOBJS_ = $(CXXSRCS:.cc=.o)
> CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
> # AS source names
> ASSRCS =
> ASOBJS_ = $(ASSRCS:.s=.o)
> ASOBJS = $(ASOBJS_:%=${ARCH}/%)
> # Libraries
> LIBS = -lrtemsall -lc
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> include $(RTEMS_CUSTOM)
> include $(PROJECT_ROOT)/make/leaf.cfg
> OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
> all: ${ARCH} $(PGM)
> $(PGM): $(OBJS)
> $(make-exe)
> j:
> @echo $(CFLAGS_DEBUG_V)
> @echo $(RTEMS_USE_GCC272)
> _________________________________________________________________
> Add photos to your messages with MSN Premium. Get 2 months FREE*
> http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
