Downloading RTEMS
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 6 21:51:23 UTC 2004
kmedri kmedri wrote:
>> I am trying to download RTEMS for my Linux OS. I used the RTEMS
>> Download Helper and got the listed files I needed. I tried to used
>> the link to get the listed files, and I got an error page" The page
>> cannot be displayed". I located the same file in a RPM form. I
>> tried to install them with RPM, but I get a message I am missing a
>> RTEMS Base file. Where is this file located of this file? Or am I
>> doing something wrong?
The -base portion is the target CPU independent part of the tool
installation. For example, the documentation for gcc is the same
for all target gcc's. You have to download a base and a target
specific RPM. See
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0/share/rtems/html/started/started00025.html
which gives the list for a sparc example.
And with a tip of the hat to Ralf, you can also use apt or
yum and greatly simplify the entire job.
> I noticed that depending on which release/version you choose there's a
> double slash "//" in the url. You may be able to just remove one of
> them, I navigated manually to the appropriate files.
Please file a PR on that if you remember it.
_________________________________________________________________
> MSN Premium helps eliminate e-mail viruses. Get 2 months FREE*
> http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
