Downloading RTEMS
McCombs, James (AGRE) James.McCombs at smiths-aerospace.com
Wed Apr 7 13:04:37 UTC 2004
Joel, Kmedri,
   Thanks for the information.  Now I need the path for the base files for the RTMEMS m68k  target?  The Download Helper is not working for me.
James
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Tuesday, April 06, 2004 5:51 PM
To: kmedri kmedri
Cc: rtems-users at rtems.com
Subject: Re: Downloading RTEMS
kmedri kmedri wrote:
>> I am trying to download RTEMS for my Linux OS.  I used the RTEMS
>> Download Helper  and got the listed files I needed.  I tried to used
>> the link to get the listed files, and I got an error page" The page
>> cannot be displayed".  I located the same file in a RPM form.   I
>> tried to install them with RPM,  but I get a message I am missing a
>> RTEMS Base file.  Where is this file located of this file?  Or am I
>> doing something wrong?
The -base portion is the target CPU independent part of the tool
installation.  For example, the documentation for gcc is the same
for all target gcc's.  You have to download a base and a target
specific RPM.  See
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0/share/rtems/html/started/started00025.html
which gives the list for a sparc example.
And with a tip of the hat to Ralf, you can also use apt or
yum and greatly simplify the entire job.
> I noticed that depending on which release/version you choose there's a
> double slash "//" in the url. You may be able to just remove one of
> them, I navigated manually to the appropriate files.
Please file a PR on that if you remember it.
_________________________________________________________________
> MSN Premium helps eliminate e-mail viruses. Get 2 months FREE*
> http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
The information contained in, or attached to, this e-mail, may contain confidential information and is intended solely for the use of the individual or entity to whom they are addressed and may be subject to legal privilege.  If you have received this e-mail in error you should notify the sender immediately by reply e-mail, delete the message from your system and notify your system manager.  Please do not copy it for any purpose, or disclose its contents to any other person.  The views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of the company.  The recipient should check this e-mail and any attachments for the presence of viruses.  The company accepts no liability for any damage caused, directly or indirectly, by any virus transmitted in this email.
