help build sparc/erc32 or mips/
Pablo Casado
pcasado at absamail.co.za
Tue Aug 3 19:08:35 UTC 2004
Hi,
I'm trying to build rtems for the sparc/erc32 or mips/ on cygwin, gcc 3.3.1,
rtems 4.6.1.
The initial configure works fine but then in the make all, another configure
script in the erc32 and jmr3904 directory throws its toys. Any help would be
appreciated.
The error for erc32 is:
configure:2794: checking for C compiler default output
configure:2797: sparc-rtems-gcc conftest.c >&5
/opt/rtems-4.6/lib/gcc-lib/sparc-rtems/3.2.3/../../../../sparc-rtems/bin/ld:
cannot open crt0.o: No such file or directory
The error for jmr3904 is
configure:2797: mips-rtems-gcc conftest.c >&5
/opt/rtems-4.6/lib/gcc-lib/mips-rtems/3.2.3/../../../../mips-rtems/lib/libc.
a: file not recognized: File truncated
collect2: ld returned 1 exit status
My toolset version are:
base-binutils 2.13.2.1-2
base-gcc 3.2.3 newlib 1.11.0-4
base-gdb 5.2.1
mips-binutils 2.13.2.1-2
mips-gcc 3.2.3 newlib 1.11.0-4
mips-gdb 5.2.1
spar-binutils 2.13.2.1-2
sparc-gcc 3.2.3 newlib 1.11.0-4
sparc-gdb 5.2.1
thanks
Pablo.
