help build sparc/erc32 or mips/
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Aug 3 19:22:41 UTC 2004
Pablo Casado wrote:
> Hi,
> I'm trying to build rtems for the sparc/erc32 or mips/ on cygwin, gcc 3.3.1,
> rtems 4.6.1.
> The initial configure works fine but then in the make all, another configure
> script in the erc32 and jmr3904 directory throws its toys. Any help would be
> appreciated.
> The error for erc32 is:
> configure:2794: checking for C compiler default output
> configure:2797: sparc-rtems-gcc    conftest.c  >&5
> /opt/rtems-4.6/lib/gcc-lib/sparc-rtems/3.2.3/../../../../sparc-rtems/bin/ld:
> cannot open crt0.o: No such file or directory
> The error for jmr3904 is
> configure:2797: mips-rtems-gcc    conftest.c  >&5
> /opt/rtems-4.6/lib/gcc-lib/mips-rtems/3.2.3/../../../../mips-rtems/lib/libc.
> a: file not recognized: File truncated
> collect2: ld returned 1 exit status
Try the procedure here and let's see what's up...
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.1/share/rtems/html/started/started00056.html
DO the "-c" test there and then try to do a full compile/link with
this:
int main() { return 0; }
configure is trying something like the above when it fails.  You can
add a -v to see the details.
Do you have the Cygwin filesystem mounts in binary mode?
--joel
> My toolset version are:
> base-binutils 2.13.2.1-2
> base-gcc 3.2.3 newlib 1.11.0-4
> base-gdb 5.2.1
> mips-binutils 2.13.2.1-2
> mips-gcc 3.2.3 newlib 1.11.0-4
> mips-gdb 5.2.1
> spar-binutils 2.13.2.1-2
> sparc-gcc 3.2.3 newlib 1.11.0-4
> sparc-gdb 5.2.1
> thanks
> Pablo.
