GRUB boot configuration file diffs to pc386 HOWTO (Modified by Peter Dufault)
Peter Dufault dufault at hda.com
Thu Aug 19 12:17:17 UTC 2004
Attached are the diffs.  This is based on what I did, but I use FreeBSD
and my dhcpd.conf is different so this should be tested on a Linux
system to verify it applies as written.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20040819/bec6e583/attachment.txt>
Peter Dufault
HD Associates, Inc.
