RPM question (old linux version)
gene smith gene.smith at siemens.com
Thu Aug 19 16:33:01 UTC 2004
I see that the tool RPMs are in a directory contain rh7.3 in its path,
i.e. ftp.rtems.com/pub/rtems/linux/redhat/7.3/i386/rpms/rtems-4.6/
I think this just means that the rpm's were build with verion 7.3. I
have seen they work with fc2 version. However, can I expect them to work
with a really old version, e.g., rh 6.1? When I try to install I get a
dependency error:
[root at 96J076 archive]# rpm -iv
rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-4.i386.rpm
error: failed dependencies:
         rpmlib(PayloadFilesHavePrefix) <= 4.0-1 is needed by
         rpmlib(CompressedFileNames) <= 3.0.4-1 is needed by
-gene
