make problem with cygwin
Steve Holle sholle at link-comm.com
Thu Aug 26 16:18:01 UTC 2004
This is my build script :
#! /bin/bash
rm -rf build
mkdir build
cd build
export PATH=$PATH:/opt/rtems-4.6/bin
/rtems/rtems-4.6.0pre5/configure --target=m68k-rtems --enable-rtemsbsp=tcb2
--enable-cxx
make all
This is the results of cygcheck - c
>$ cygcheck -c
>Cygwin Package Information
>Package                 Version            Status
>_update-info-dir        00227-1            OK
>ash                     20040127-1         OK
>autoconf                2.59-1             OK
>autoconf-devel          2.59-1             OK
>autoconf-stable         2.13-5             OK
>automake                1.7.9-1            OK
>automake-devel          1.7.9-1            OK
>automake-stable         1.4p6-2            OK
>base-files              2.6-1              OK
>base-passwd             1.1-1              OK
>bash                    2.05b-16           OK
>binutils                20040312-1         OK
>bzip2                   1.0.2-5            OK
>cgoban                  1.9.14-1           OK
>crypt                   1.1-1              OK
>cygipc                  2.03-2             OK
>cygrunsrv               1.0-1              OK
>cygutils                1.2.5-1            OK
>cygwin                  1.5.10-3           OK
>ddd                     3.3.8-1            OK
>diffutils               2.8.7-1            OK
>editrights              1.01-1             OK
>expat                   1.95.7-1           OK
>fileutils               4.1-2              OK
>findutils               4.1.7-4            OK
>flex                    2.5.4a-3           OK
>fltk                    1.1.4-2            OK
>fontconfig              2.2.2-1            OK
>freetype2               2.1.5-1            OK
>fvwm                    2.4.7-3            OK
>gawk                    3.1.3-4            OK
>gcc                     3.3.1-3            Incomplete
>gcc-ada                 3.3.1-3            OK
>gcc-g++                 3.3.1-3            OK
>gcc-mingw               20030911-4         OK
>gcc-mingw-ada           20031020-1         OK
>gcc-mingw-core          20031020-1         OK
>gcc-mingw-g++           20031020-1         OK
>gdb                     20030919-1         OK
>gdbm                    1.8.3-7            OK
>gettext                 0.12.1-3           OK
>ghostscript             7.05-2             OK
>ghostscript-base        7.05-2             OK
>ghostscript-x11         7.05-2             OK
>gnugo                   3.4-1              OK
>grace                   5.1.12-1           OK
>grep                    2.5-1              OK
>groff                   1.18.1-2           OK
>gv                      3.5.8-1            OK
>gzip                    1.3.5-1            OK
>jpeg                    6b-11              OK
>less                    381-1              OK
>lesstif                 0.93.91-6          OK
>libbz2_1                1.0.2-5            OK
>libdb3.1                3.1.17-2           OK
>libdb3.1-devel          3.1.17-2           OK
>libdb4.1                4.1.25-1           OK
>libfontconfig-devel     2.2.2-1            OK
>libfontconfig1          2.2.2-1            OK
>libfreetype2-devel      2.1.5-1            OK
>libfreetype26           2.1.5-1            OK
>libgdbm                 1.8.0-5            OK
>libgdbm-devel           1.8.3-7            OK
>libgdbm3                1.8.3-3            OK
>libgdbm4                1.8.3-7            OK
>libgettextpo0           0.12.1-3           OK
>libiconv2               1.9.1-3            OK
>libintl                 0.10.38-3          OK
>libintl1                0.10.40-1          OK
>libintl2                0.12.1-3           OK
>libjpeg62               6b-11              OK
>libjpeg6b               6b-8               OK
>libncurses5             5.2-1              OK
>libncurses6             5.2-8              OK
>libncurses7             5.3-4              OK
>libpcre                 4.1-1              OK
>libpcre0                4.5-1              OK
>libpng                  1.2.5-4            OK
>libpng10                1.0.15-4           OK
>libpng12                1.2.5-4            OK
>libpopt0                1.6.4-4            OK
>libreadline4            4.1-2              OK
>libreadline5            4.3-5              OK
>libtiff-devel           3.6.0-5            OK
>libtiff3                3.6.0-2            OK
>libtiff4                3.6.0-5            OK
>libungif                4.1.0-3            OK
>libXft                  2.1.6-1            OK
>libXft-devel            2.1.6-1            OK
>libXft1                 1.0.0-1            OK
>libXft2                 2.1.6-1            OK
>login                   1.9-7              OK
>lynx                    2.8.4-7            OK
>m4                      1.4-1              OK
>make                    3.80-1             OK
>man                     1.5k-3             OK
>mingw-runtime           3.3-1              OK
>minires                 0.97-1             OK
>mktemp                  1.5-3              OK
>ncurses                 5.3-4              OK
>nedit                   5.4-1              OK
>openbox                 0.99.1-4           OK
>openssh                 3.8.1p1-1          OK
>openssl                 0.9.7d-1           OK
>patch                   2.5.8-8            OK
>pcre                    4.5-1              OK
>pcre-doc                4.5-1              OK
>perl                    5.8.2-1            OK
>readline                4.3-5              OK
>sed                     4.0.9-2            OK
>sh-utils                2.0.15-4           OK
>sharutils               4.2.1-3            OK
>tar                     1.13.25-5          OK
>tcltk                   20030901-1         OK
>termcap                 20021106-2         OK
>terminfo                5.3_20030726-1     OK
>texinfo                 4.2-4              OK
>textutils               2.0.21-1           OK
>tiff                    3.6.0-5            OK
>transfig                3.2.4-2            OK
>w32api                  2.5-1              OK
>which                   1.5-2              OK
>WindowMaker             0.80.2-1           OK
>X-start-menu-icons      1.0.1-1            OK
>X-startup-scripts       1.0.7-1            OK
>x2x                     1.30-2             OK
>Xaw3d                   1.5D-5             OK
>xfig                    3.2.4-6            OK
>xfig-bin                3.2.4-3            OK
>xfig-doc                3.2.4-2            OK
>xfig-etc                3.2.4-4            OK
>xfig-lib                3.2.4-6            OK
>xfig-man                3.2.4-2            OK
>XFree86-base            4.3.0-11           OK
>XFree86-bin             4.3.0-21           OK
>XFree86-bin-icons       4.3.0-7            OK
>XFree86-doc             4.3.0-2            OK
>XFree86-etc             4.3.0-12           OK
>XFree86-f100            4.3.0-2            OK
>XFree86-fcyr            4.3.0-2            OK
>XFree86-fenc            4.3.0-2            OK
>XFree86-fnts            4.3.0-2            OK
>XFree86-fscl            4.3.0-2            OK
>XFree86-fsrv            4.3.0-9            OK
>XFree86-html            4.3.0-10           OK
>XFree86-jdoc            4.3.0-2            OK
>XFree86-lib             4.3.0-3            OK
>XFree86-lib-compat      4.3.0-2            OK
>XFree86-man             4.3.0-10           OK
>XFree86-nest            4.3.0-8            OK
>XFree86-prog            4.3.0-21           OK
>XFree86-prt             4.3.0-6            OK
>XFree86-ps              4.3.0-2            OK
>XFree86-startup-scripts 4.3.0-1            OK
>XFree86-vfb             4.3.0-8            OK
>XFree86-xserv           4.3.0-68           OK
>XFree86-xwinclip        4.3.0-3            OK
>xgraph                  12.1-1             OK
>XmHTML                  1.1.7-1            OK
>xorg-x11-base           6.7.0.0-8          OK
>xorg-x11-bin            6.7.0.0-4          OK
>xorg-x11-bin-dlls       6.7.0.0-4          OK
>xorg-x11-bin-lndir      6.7.0.0-2          OK
>xorg-x11-devel          6.7.0.0-4          OK
>xorg-x11-etc            6.7.0.0-3          OK
>xorg-x11-f100           6.7.0.0-1          OK
>xorg-x11-fcyr           6.7.0.0-1          OK
>xorg-x11-fenc           6.7.0.0-2          OK
>xorg-x11-fnts           6.7.0.0-1          OK
>xorg-x11-fscl           6.7.0.0-3          OK
>xorg-x11-fsrv           6.7.0.0-1          OK
>xorg-x11-libs-data      6.7.0.0-2          OK
>xorg-x11-man-pages      6.7.0.0-2          OK
>xorg-x11-man-pages-html 6.7.0.0-2          OK
>xorg-x11-nest           6.7.0.0-2          OK
>xorg-x11-vfb            6.7.0.0-2          OK
>xorg-x11-xwin           6.7.0.0-9          OK
>xterm                   185-4              OK
>xwinclip                1.2.0-1            OK
>zlib                    1.2.1-1            OK
Steve Holle
Link Communications, Inc.
1035 Cerise Rd.
Billings, MT  59101
