make problem with cygwin
Ralf Corsepius ralf_corsepius at rtems.org
Fri Aug 27 04:16:15 UTC 2004
On Thu, 2004-08-26 at 18:18, Steve Holle wrote:
> This is my build script :
> #! /bin/bash
> rm -rf build
> mkdir build
> cd build
> export PATH=$PATH:/opt/rtems-4.6/bin
Please prepend the directory of the RTEMS binaries, i.e. use
export PATH=/opt/rtems-4.6/bin:$PATH
You are appending the /opt/rtems-4.6/bin, which will give the system
tools preference to the rtems-tools.
E.g. you have the Cygwin autotools installed. Your PATH will cause them
to be picked up instead of the RTEMS autotools and can result into
problems.
> /rtems/rtems-4.6.0pre5/configure --target=m68k-rtems --enable-rtemsbsp=tcb2
> --enable-cxx
> make all
> This is the results of cygcheck - c
Joel, now it would be interesting to see a comparison to the versions
you have installed.
Highly interesting are: m4, bash, sed, make, cygwin, gawk.
> >$ cygcheck -c
> >Cygwin Package Information
> >Package                 Version            Status
> >_update-info-dir        00227-1            OK
> >ash                     20040127-1         OK
> >autoconf                2.59-1             OK
> >autoconf-devel          2.59-1             OK
> >autoconf-stable         2.13-5             OK
> >automake                1.7.9-1            OK
> >automake-devel          1.7.9-1            OK
> >automake-stable         1.4p6-2            OK
> >base-files              2.6-1              OK
> >base-passwd             1.1-1              OK
> >bash                    2.05b-16           OK
> >binutils                20040312-1         OK
> >bzip2                   1.0.2-5            OK
> >cgoban                  1.9.14-1           OK
> >crypt                   1.1-1              OK
> >cygipc                  2.03-2             OK
> >cygrunsrv               1.0-1              OK
> >cygutils                1.2.5-1            OK
> >cygwin                  1.5.10-3           OK
> >ddd                     3.3.8-1            OK
> >diffutils               2.8.7-1            OK
> >editrights              1.01-1             OK
> >expat                   1.95.7-1           OK
> >fileutils               4.1-2              OK
> >findutils               4.1.7-4            OK
> >flex                    2.5.4a-3           OK
> >fltk                    1.1.4-2            OK
> >fontconfig              2.2.2-1            OK
> >freetype2               2.1.5-1            OK
> >fvwm                    2.4.7-3            OK
> >gawk                    3.1.3-4            OK
> >gcc                     3.3.1-3            Incomplete
> >gcc-ada                 3.3.1-3            OK
> >gcc-g++                 3.3.1-3            OK
> >gcc-mingw               20030911-4         OK
> >gcc-mingw-ada           20031020-1         OK
> >gcc-mingw-core          20031020-1         OK
> >gcc-mingw-g++           20031020-1         OK
> >gdb                     20030919-1         OK
> >gdbm                    1.8.3-7            OK
> >gettext                 0.12.1-3           OK
> >ghostscript             7.05-2             OK
> >ghostscript-base        7.05-2             OK
> >ghostscript-x11         7.05-2             OK
> >gnugo                   3.4-1              OK
> >grace                   5.1.12-1           OK
> >grep                    2.5-1              OK
> >groff                   1.18.1-2           OK
> >gv                      3.5.8-1            OK
> >gzip                    1.3.5-1            OK
> >jpeg                    6b-11              OK
> >less                    381-1              OK
> >lesstif                 0.93.91-6          OK
> >libbz2_1                1.0.2-5            OK
> >libdb3.1                3.1.17-2           OK
> >libdb3.1-devel          3.1.17-2           OK
> >libdb4.1                4.1.25-1           OK
> >libfontconfig-devel     2.2.2-1            OK
> >libfontconfig1          2.2.2-1            OK
> >libfreetype2-devel      2.1.5-1            OK
> >libfreetype26           2.1.5-1            OK
> >libgdbm                 1.8.0-5            OK
> >libgdbm-devel           1.8.3-7            OK
> >libgdbm3                1.8.3-3            OK
> >libgdbm4                1.8.3-7            OK
> >libgettextpo0           0.12.1-3           OK
> >libiconv2               1.9.1-3            OK
> >libintl                 0.10.38-3          OK
> >libintl1                0.10.40-1          OK
> >libintl2                0.12.1-3           OK
> >libjpeg62               6b-11              OK
> >libjpeg6b               6b-8               OK
> >libncurses5             5.2-1              OK
> >libncurses6             5.2-8              OK
> >libncurses7             5.3-4              OK
> >libpcre                 4.1-1              OK
> >libpcre0                4.5-1              OK
> >libpng                  1.2.5-4            OK
> >libpng10                1.0.15-4           OK
> >libpng12                1.2.5-4            OK
> >libpopt0                1.6.4-4            OK
> >libreadline4            4.1-2              OK
> >libreadline5            4.3-5              OK
> >libtiff-devel           3.6.0-5            OK
> >libtiff3                3.6.0-2            OK
> >libtiff4                3.6.0-5            OK
> >libungif                4.1.0-3            OK
> >libXft                  2.1.6-1            OK
> >libXft-devel            2.1.6-1            OK
> >libXft1                 1.0.0-1            OK
> >libXft2                 2.1.6-1            OK
> >login                   1.9-7              OK
> >lynx                    2.8.4-7            OK
> >m4                      1.4-1              OK
> >make                    3.80-1             OK
> >man                     1.5k-3             OK
> >mingw-runtime           3.3-1              OK
> >minires                 0.97-1             OK
> >mktemp                  1.5-3              OK
> >ncurses                 5.3-4              OK
> >nedit                   5.4-1              OK
> >openbox                 0.99.1-4           OK
> >openssh                 3.8.1p1-1          OK
> >openssl                 0.9.7d-1           OK
> >patch                   2.5.8-8            OK
> >pcre                    4.5-1              OK
> >pcre-doc                4.5-1              OK
> >perl                    5.8.2-1            OK
> >readline                4.3-5              OK
> >sed                     4.0.9-2            OK
> >sh-utils                2.0.15-4           OK
> >sharutils               4.2.1-3            OK
> >tar                     1.13.25-5          OK
> >tcltk                   20030901-1         OK
> >termcap                 20021106-2         OK
> >terminfo                5.3_20030726-1     OK
> >texinfo                 4.2-4              OK
> >textutils               2.0.21-1           OK
> >tiff                    3.6.0-5            OK
> >transfig                3.2.4-2            OK
> >w32api                  2.5-1              OK
> >which                   1.5-2              OK
> >WindowMaker             0.80.2-1           OK
> >X-start-menu-icons      1.0.1-1            OK
> >X-startup-scripts       1.0.7-1            OK
> >x2x                     1.30-2             OK
> >Xaw3d                   1.5D-5             OK
> >xfig                    3.2.4-6            OK
> >xfig-bin                3.2.4-3            OK
> >xfig-doc                3.2.4-2            OK
> >xfig-etc                3.2.4-4            OK
> >xfig-lib                3.2.4-6            OK
> >xfig-man                3.2.4-2            OK
> >XFree86-base            4.3.0-11           OK
> >XFree86-bin             4.3.0-21           OK
> >XFree86-bin-icons       4.3.0-7            OK
> >XFree86-doc             4.3.0-2            OK
> >XFree86-etc             4.3.0-12           OK
> >XFree86-f100            4.3.0-2            OK
> >XFree86-fcyr            4.3.0-2            OK
> >XFree86-fenc            4.3.0-2            OK
> >XFree86-fnts            4.3.0-2            OK
> >XFree86-fscl            4.3.0-2            OK
> >XFree86-fsrv            4.3.0-9            OK
> >XFree86-html            4.3.0-10           OK
> >XFree86-jdoc            4.3.0-2            OK
> >XFree86-lib             4.3.0-3            OK
> >XFree86-lib-compat      4.3.0-2            OK
> >XFree86-man             4.3.0-10           OK
> >XFree86-nest            4.3.0-8            OK
> >XFree86-prog            4.3.0-21           OK
> >XFree86-prt             4.3.0-6            OK
> >XFree86-ps              4.3.0-2            OK
> >XFree86-startup-scripts 4.3.0-1            OK
> >XFree86-vfb             4.3.0-8            OK
> >XFree86-xserv           4.3.0-68           OK
> >XFree86-xwinclip        4.3.0-3            OK
> >xgraph                  12.1-1             OK
> >XmHTML                  1.1.7-1            OK
> >xorg-x11-base           6.7.0.0-8          OK
> >xorg-x11-bin            6.7.0.0-4          OK
> >xorg-x11-bin-dlls       6.7.0.0-4          OK
> >xorg-x11-bin-lndir      6.7.0.0-2          OK
> >xorg-x11-devel          6.7.0.0-4          OK
> >xorg-x11-etc            6.7.0.0-3          OK
> >xorg-x11-f100           6.7.0.0-1          OK
> >xorg-x11-fcyr           6.7.0.0-1          OK
> >xorg-x11-fenc           6.7.0.0-2          OK
> >xorg-x11-fnts           6.7.0.0-1          OK
> >xorg-x11-fscl           6.7.0.0-3          OK
> >xorg-x11-fsrv           6.7.0.0-1          OK
> >xorg-x11-libs-data      6.7.0.0-2          OK
> >xorg-x11-man-pages      6.7.0.0-2          OK
> >xorg-x11-man-pages-html 6.7.0.0-2          OK
> >xorg-x11-nest           6.7.0.0-2          OK
> >xorg-x11-vfb            6.7.0.0-2          OK
> >xorg-x11-xwin           6.7.0.0-9          OK
> >xterm                   185-4              OK
> >xwinclip                1.2.0-1            OK
> >zlib                    1.2.1-1            OK
Ralf
