make problem with cygwin
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Aug 27 14:34:56 UTC 2004
THis does not fail on my home PC.  It is a P4 running XP Pro.
It should be a fairly clean machine as I had a hard disk die and
had to reload from OS disks a few months ago.  Is there anything
to learn from comparing something on the two machines?
This morning I just upgraded the Cygwin on the dual CPU
machine that failed earlier this week.  It now works.
Is everyone who experiences this problem running the
latest and greatest Cygwin?
--joel
Ralf Corsepius wrote:
> On Fri, 2004-08-27 at 00:28, Joel Sherrill  wrote:
>>Martin R. Calsyn wrote:
>>>Ahh - having $(LIB) set could be it.  If you have almost any version of
>>>Microsoft Visual Studio installed, LIB and INCLUDE will be set in global
>>>environment variables and make will pick up those settings.
>>That's a known one that's bad.
> There even is an entry on this topic in the FAQ ;)
> BTW:
> * LIB is supposed to be worked around in rtems-4.7/CVS for quite a
> while.
> * INCLUDE had never been used.
>> Also having spaces in your PATH is bad.
>>But I don't have those issues and still get it.
>>I have a TEMP and TMP set.
> AFAIK, TEMP is DOS/WIN specific, TMP isn't and could interfere.
> Both are not explicitly used by RTEMS's configuration, but they could be
> used by tools. One would have to check these tools source code to be
> sure ;)
>>  Some variables with paths do have ~'s in them.
> Do you mean *nixish "$HOME"s or WIN'ish shortened directories?
> Do you mean paths or directories?
> All of them are unsafe and can be troublesome. However, I don't think
> they do any harm unless they are in environment variables being used by
> cygwin or configure scripts (I.e. TMP, PATH, CWD/PWD)
>>Ralf.. if you suspect something on this line, I can privately email
>>you the env output.
> Though I can't exclude anything, I don't expect this to be cause for the
> "build_alias" problem.
> Ralf
