cygwin build_alias issue
    Scott Newell
    newell at cei.net
    Tue Aug 31 19:04:28 UTC 2004
At 01:30 PM 8/31/2004 , Joel Sherrill <joel at OARcorp.com> wrote:
>I think I have a hint about this.  My system configures
>correctly when I explicitly specify a single BSP to configure
>with (--enable-rtemsbsp=XXX) but fails with the build_alias
>error when that option is not specified or a set of
>BSPs is specified.
No help here:
../rtems-4.6.1/configure --target=m68k-rtems --disable-posix
--disable-networking --disable-cxx --enable-rtemsbsp=efi332 2>&1 | tee -a
log.txt
gmake all 2>&1 | tee -a log.txt
checking for m68k-rtems-ar... m68k-rtems-ar
checking for m68k-rtems-as... m68k-rtems-as
checking for m68k-rtems-ld... m68k-rtems-ld
checking for m68k-rtems-nm... m68k-rtems-nm
checking for m68k-rtems-ranlib... m68k-rtems-ranlib
checking for m68k-rtems-objcopy... m68k-rtems-objcopy
checking for m68k-rtems-size... m68k-rtems-size
checking for m68k-rtems-strip... (cached) m68k-rtems-strip
checking if wanting multiprocessing... no
configure: creating ./config.status
configure: configuring in ../../cpukit
configure: running /bin/bash
'../../../../../rtems-4.6.1/c/src/../../cpukit/configure'
'--prefix=/opt/rtems-4.6' '--host=m68k-rtems' '--build=i686-pc-cygwin'
'--target=m68k-rtems' '--disable-posix' '--disable-networking'
'--disable-cxx' '--with-target-subdir=m68k-rtems'
'--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=efi332'
'RTEMS_CPU_MODEL=m68332' 'RTEMS_BSP_FAMILY=efi332' 'CPU_CFLAGS=-mcpu32'
'CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer' '--with-project-root=../../'
'--enable-rtemsbsp=efi332'
   --cache-file=/dev/null
--srcdir=../../../../../rtems-4.6.1/c/src/../../cpukit
configure: error: invalid variable name: build_alias
configure: error: /bin/bash
'../../../../../rtems-4.6.1/c/src/../../cpukit/configure' failed for
../../cpukit
gmake[2]: *** [efi332] Error 1
gmake[2]: Leaving directory `/build_02/m68k-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/build_02/m68k-rtems/c'
gmake: *** [all-recursive] Error 1
I also tried quoting the bsp:
--disable-networking --disable-cxx --enable-rtemsbsp="efi332" 2>&1 | tee -a
log.txt
Same error during the make:
../../cpukit
gmake[2]: Leaving directory `/build_03/m68k-rtems/c'
gmake[1]: Leaving directory `/build_03/m68k-rtems/c'
newell
