cygwin configure problem
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Aug 18 17:09:55 UTC 2004
Gene Smith wrote:
> Ralf Corsepius wrote, On 08/17/2004 09:44 PM:
>> On Tue, 2004-08-17 at 19:23, Smith, Gene wrote:
>>> Ralf Corsepius wrote, On 8/17/2004 11:47 AM:
>>>> On Tue, 2004-08-17 at 17:16, Smith, Gene wrote:
>>>>> cd `pwd`
>>>>> Pwd generates a string containing "Documents and Settings" but cd
>>>>> trucates it at the first un-escaped space producing just
>>>>> ".../Documents" which causes the choke.
>>>>> Guess I will have to move my rtems stuff to where the cygwin path
>>>>> contains no spaces.
>>>> Exactly. It's a general limitation with all autoconf generated
>>>> configure
>>>> scripts. There are occasions where quoting strings containing white
>>>> spaces fail. Sometimes, the cause is a bug in autoconf, sometimes the
>>>> cause is a bug in the shell being used, sometimes it's a bug elsewhere.
>> FWIW: The bug you've hit is a quoting bug in RTEMS.
>> Once having fixed this one you'll trip a similar known quoting bug in
>> autoconf, which already had been fixed in autoconf CVS, but is still
>> open in released version. Later, you'll trip yet another a new quoting
>> bug in autoconf :)
> Any bugzilla numbers for these looming bugs?
>>>> Rule of thumb: Don't use whitespaces.
>>>> Ralf
>>> I agree. They are evil in pathnames, email address, URLs etc. But some
>>> OS vendors seem to encourage them. ;)
>>> Anyhow, I moved my rtems stuff to a space-free path and now am stumped
>>> again. Spits out this after going a while,
>>> configure: error: invalid variable name: build_alias
>>> configure: error: /bin/sh
>>> '../../../../rtems-4.6.1/tools/cpu/generic/configure' failed for generic
>>> configure: error: /bin/sh '../../../rtems-4.6.1/tools/cpu/configure'
>>> failed for tools/cpu
>> This issue had been reported many times (Please check this list's
>> archives).
>> I am not using Cygwin myself, and therefore hardly can help, but AFAIU
>> the Cygwin users' reports, this is a bug in Cygwin.
The PC I am using today has a fairly recent but not completely current
Cygwin installation and it exhibits this problem when Norton AntiVirus
is enabled or disabled.
If I specify --build=i386-cygwin on the top level configure, I managed
to get configured but when it finished doing configure as part of make,
it failed with the build_alias message.
I can provide the "bash -x" log of a failed configure if anyone
cares.
Interestingly, I built a test m68k executable of "main() {}" and
tried to run it with NAV enabled and it was allowed with no
NAV messages.
--joel
