"build_alias" again in cygwin
Ralf Corsepius
ralf_corsepius at rtems.org
Wed Aug 25 14:54:04 UTC 2004
On Wed, 2004-08-25 at 16:17, Steve Holle wrote:
> I'm the co-worker Steve Strobel referred to. I can't say for sure but the
> one thing I did that Steve hasn't was to go through and upgrade everything
> that showed needing upgrade in my cygwin tree. I have to suspect this is a
> cygwin problem but am not sure why mine builds. If there is some info from
> my system someone thinks would be helpful, let me know and I'll post it.
Another wild guess: Does your system apply HyperThreading?
Besides this, I would be interested in seeing a list of *all* cygwin
packages you have installed.
> I am still not able, however, to do an incremental build so each build
> takes 30 minutes.
What exactly are you doing? Please describe each and every single step
in detail.
> I would not recommend cygwin for anyone starting a new
> RTEMS project. The time wasted is huge.
<*G*/> I would not recommend using Windows ;)
Ralf
