General configure question followup
Ralf Corsepius
ralf_corsepius at rtems.org
Thu Aug 26 16:21:05 UTC 2004
On Thu, 2004-08-26 at 17:50, Peter Dufault wrote:
> This is a follow up to Mark Mussetter's questions about configuring VNC.
> I had a method to configure Tcl, but after reading Ralf Cersepius's
> reply to Mark I realize it was probably wrong. So I've gotten back to
> that project and want to do it right.
> RTEMS is built and everything works fine. I'm building for pc586,
> using the suggested paths, etc.
> To configure Tcl I'm trying to do this:
> ./configure \
> --host=i386-rtems \
> --exec-prefix=i386-rtems- \
> --disable-threads \
> --disable-load \
> --disable-shared \
> --enable-symbols \
> --disable-langinfo
> The tools are in /opt/rtems-4.6/bin as i386-rtems-foo, and
> /opt/rtems-4.6/bin is in my search path.
> However, using the above configure line, configure is using the system
> gcc and not i386-rtems-gcc.
> I'd gotten around this in my first attempts by wrapping the configure
> in a shell script that did things such as:
> export CC_FOR_TARGET='i386-rtems-gcc
> -B/opt/rtems-4.6/i386-rtems/pc586/lib/ -specs bsp_specs -qrtems'
> export CC="${CC_FOR_TARGET}"
> before doing the configure, but Ralf's previous comments make me think
> this is the wrong way to do it.
> What's the right way?
Neither ;)
What I had said, referred to "packages using autoconf-2.5x
configurations" and current GNU-standards.
Cross compiliing packages which still use "autoconf < 2.50 apply
different convention and are not unlikely to require steps similar to
those you describe above (CC=<host>-gcc ./configure).
I am not familiar with tcl to the extend to be able to comment on
details, but ... tcl had always been a very "special" beast which has
always required "special" treatment for cross-compilation.
IIRC, tcl still applies autoconf-2.13 and hand-written Makefiles. So
what you describe, might very likely be correct for tcl.
Ralf
