make problem with cygwin
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Aug 26 22:28:26 UTC 2004
Martin R. Calsyn wrote:
> Ahh - having $(LIB) set could be it.  If you have almost any version of
> Microsoft Visual Studio installed, LIB and INCLUDE will be set in global
> environment variables and make will pick up those settings.
That's a known one that's bad.  Also having spaces in your PATH is bad.
But I don't have those issues and still get it.
I have a TEMP and TMP set.  Some variables with paths do have ~'s in
them.
Ralf.. if you suspect something on this line, I can privately email
you the env output.
> -----Original Message-----
> From: Ralf Corsepius [mailto:ralf_corsepius at rtems.org]
> Sent: Thursday, August 26, 2004 8:57 AM
> To: Martin R. Calsyn
> Cc: Haberhausen, Dierk; RTEMS Users
> Subject: RE: make problem with cygwin
> On Thu, 2004-08-26 at 17:13, Martin R. Calsyn wrote:
>>I ran into this same problem.  The 'multiple targets' error is a bit
>>misleading.  I solved the error by removing the .PRECIOUS
> entry/entries
>>on or immediately before the line indicated (567 in your example
> below).
>>I encountered this in perhaps six makefiles and each time it was
> solved
>>by removing a dotted makefile directive.
>>I haven't dug deeper into why this is happening - it seems to be an
>>incompatibility with the 'make' packaged in cygwin.
>>  I haven't submitted
>>deltas because I don't have enough confidence that this is a proper
> fix
>>or just a workaround for cygwin weirdness.
> I am pretty sure it is not. Conversely, I am pretty sure it will do
> harm.
> I'd guess, the cause is Dierk having $(LIB) or $(ARCH) set in his
> environment:
> .PRECIOUS: $(LIB)
> ${ARCH}/%.$(OBJEXT): sapi/%.c
>         ${COMPILE} -o $@ -c $<
> ${ARCH}/%.$(OBJEXT): rtems/%.c
> Ralf
