make problem with cygwin
    Smith, Gene
    gene.smith at siemens.com
    Fri Aug 27 18:40:35 UTC 2004
Ralf Corsepius wrote, On 8/27/2004 12:31 PM:
> On Fri, 2004-08-27 at 16:34, Joel Sherrill  wrote:
>>THis does not fail on my home PC.  It is a P4 running XP Pro.
>>It should be a fairly clean machine as I had a hard disk die and
>>had to reload from OS disks a few months ago.  Is there anything
>>to learn from comparing something on the two machines?
> All I can tell is:
> * Steve H. reports not to have problems.
> AFAICT, his machine seems to be up to date or at least very close to
> current Cygwin.
> * Scott report to have problems. His installation is somewhat outdated.
> Here are the what I presume to be the essential diffs between their
> lists:
> --- steveh.list 2004-08-27 18:13:51.616068057 +0200
> +++ scott.list  2004-08-27 18:13:34.013326813 +0200
> @@ -1,64 +1,59 @@
I still have build_alias problem and have the new version of each
package below (except for gawk which is even newer). See below.
Also, have rtems bin tools at front of PATH.
-gene
>  bash                    2.05b-16           OK
Have the above bash
> -cygwin                  1.5.10-3           OK
> +cygwin                  1.5.5-1            OK
Have cygwin 1.5.10-3
> -gawk                    3.1.3-4            OK
> +gawk                    3.1.3-3            OK
Have gawk 3.1.4-3 (newer)
>  m4                      1.4-1              OK
No m4
>  make                    3.80-1             OK
Have the above make
>  mktemp                  1.5-3              OK
Have the above mktemp
> -sed                     4.0.9-2            OK
> +sed                     4.0.7-3            OK
Have sed 4.0.9-2
> -w32api                  2.5-1              OK
> +w32api                  2.4-1              OK
Have w32api 2.5-1
>>This morning I just upgraded the Cygwin on the dual CPU
>>machine that failed earlier this week.  It now works.
> This would fit into the picture above.
>>Is everyone who experiences this problem running the
>>latest and greatest Cygwin?
> Ralf
