rtems gdb/insight to jtag
-boggy boggy at elab.tmf.bg.ac.yu
Tue Aug 31 20:35:17 UTC 2004
Hello Erwin,
this is very nice news for me... I still use gdb 5.0 because I
don't know for your work... thank you for it...
I now download gdb-6.1.1 source... :)
thanks again and
best regards.
-boggy
Erwin Rol wrote:
> Since I was not able to get contact with the original author, I used the
> patch from VAS to write a small BDM library and to make some new patches
> for newer GDB's. I used (and probably will use it again for a future
> RTEMS-MPC860 project) it with RTEMS without to much problems, only
> dealing with break points in Interrupt handlers is a bit of a pain.
> The "new" version can be founf on my homepage;
> http://www.erwinrol.de/index.php?opensource/bdm.php
>>This cables cost about 50EUR, but that interfaces
>>are very simple (about two HC chips + possibly some diodes and
>>transistors... we built all of this in our labs... nothing special
>>we have one cable per software or hardware engineer, and this is good...)
> - Erwin
