rtems gdb/insight to jtag
Erwin Rol mailinglists at erwinrol.com
Tue Aug 31 20:14:50 UTC 2004
On Tue, 2004-08-31 at 21:32, -boggy wrote:
> Hello Gene,
> We use:
> 2. debug-cable and gdb with bdm4gdb patch for
> Motorola's MPC860 (http://www.vas-gmbh.de/software/mpcbdm/ < patch and
> cable schematic is included in tar.gz)
Since I was not able to get contact with the original author, I used the
patch from VAS to write a small BDM library and to make some new patches
for newer GDB's. I used (and probably will use it again for a future
RTEMS-MPC860 project) it with RTEMS without to much problems, only
dealing with break points in Interrupt handlers is a bit of a pain.
The "new" version can be founf on my homepage;
http://www.erwinrol.de/index.php?opensource/bdm.php
> This cables cost about 50EUR, but that interfaces
> are very simple (about two HC chips + possibly some diodes and
> transistors... we built all of this in our labs... nothing special
> we have one cable per software or hardware engineer, and this is good...)
- Erwin
      Erwin Rol Software Engineering - http://www.erwinrol.com/
tel:+49-(0)8024-479378 gsm:+49-(0)171-6929198 email:info at erwinrol.com
