qemu core dump
Tony Richardson richardson at evansville.edu
Wed Dec 15 00:55:27 UTC 2004
Joel Sherrill wrote:
> >>I was playing last night on a Pentium II running Fedora Core 3
> >>and the binary qemu from the site.  I cold run it to get the
> >>help but when I used the old grub image from the site, it always
> >>core dumped on me.  I was on the console.
> >>qemu -fda grub144 -boot a
> >>Any ideas?
> > Does qemu even work from the console?  I've never tried it.
> > The same setup works fine for me under X though.  There's
> > a -nographic option to qemu that may help?
> I'm sorry.  I meant console under X11 (Gnome) as opposed to
> across a VNC session.  I am an old UNIX type and think of
> console as just being in front of the machine.  I forget that
> means something different on Linux with the console usually
> meaning not under X.
I apologize Joel.  I thought the machine I was using was running FC3
but I later realized that it was back at FC2.  I tried the qemu binary
on a FC3 machine and got a seg fault too.  Rebuilding from source
was quick and painless however and took care of the problem, that
is, qemu works fine under FC3 when you build from source.
Tony
