"Can't obtain network semaphore"
Steve Holle
sholle at link-comm.com
Tue Dec 14 17:24:34 UTC 2004
At 09:59 AM 12/14/2004, Steve Holle wrote:
>I need to revisit this problem as I am seeing it again. The error message
>comes from "rtems_glue.c:312" and it's frequency of occurrence seems to
>move around with the build. If I place a breakpoint on that line my
>backtrace displays the following :
> #4 0x0013a108 in _Thread_Handler () at
> threadhandler.c:129
> #3 0x0011df64 in taskEntry () at rtems_glue.c:587
> #2 0x0010e3b4 in fec_tcDaemon () at network.c:698
> #1 0x0011e07e in rtems_bsdnet_event_receive () at
> rtems_glue.c:642
> #0 rtems_bsdnet_semaphore_obtain () at rtems_glue.c:312
One other piece of info. All the network threads except the streaming
audio threads are started using the rtems functions as follows :
sc = rtems_bsdnet_initialize_network ();
sc = rtems_initialize_ftpd();
sc = rtems_initialize_webserver();
My streaming audio server thread is started as follows :
rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY,
&my_priority);
rtems_id tid;
sc = rtems_task_create (rtems_build_name ('S', 'A', 'S', 'V'),
my_priority - 1,
RTEMS_MINIMUM_STACK_SIZE*4,
RTEMS_PREEMPT|RTEMS_NO_TIMESLICE|RTEMS_NO_ASR|RTEMS_INTERRUPT_LEVEL(0),
RTEMS_NO_FLOATING_POINT|RTEMS_LOCAL,
&tid);
My receive and transmit threads are started as follows :
&my_priority_r);
sc = rtems_task_create (rtems_build_name ('S', 'A', 'S', 'R'),
my_priority_r,
RTEMS_PREEMPT | RTEMS_NO_TIMESLICE |
&tidr);
&my_priority_w);
sc = rtems_task_create (rtems_build_name ('S', 'A', 'S', 'W'),
my_priority_w,
RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_NO_ASR |
&tidw);
>Any suggestions?
>Steve Holle
>Link Communications, Inc.
>1035 Cerise Rd.
>Billings, MT 59101
Steve Holle
1035 Cerise Rd.
Billings, MT 59101
