stdc++ (cout) problem with RTEMS on Sparc emulator
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Thu Dec 16 12:28:30 UTC 2004
As part of executing the first thread RTEMS will run the global
constructors from "_Thread_Handler".  gcc generates a special
function to call usually named something like __init.  It
runs global exceptions and does the ctors.  Getting the linker
script and bsp_specs right is necessary even when the toolset
works.
Also you have to link with "g++" not "gcc".
http://gcc.gnu.org/ml/gcc/2002-07/msg00352.html is a good
read on ELF and everything that has to be right for it to
work.
Can you run cdtest on the sparc/erc32 target?
--joel
Courtney B. Duncan wrote:
>>> The questions are:  Am I on the right track in tracking down this
>>> problem?  Does C++ cout work for anybody under RTEMS?  Isn't there a
>>> printf() based cout implementation that ought to work in this situation?
>> I use C++, libstdc++.a, the STL on a Coldfire processor with no problems.
> Thanks for your quick help.  After a couple of months I'm back to this.
>> Is the correct library being linked ?
> I think /usr/local/erc32/sparc-rtems/lib/libstdc++.a is the correct one
> and it is the one being linked.  All the permutations of 'revb' 'soft'
> and 'v8' are also present, and I've tried them with the same result
> (doesn't work).  The emulator says that it is V7, Rev C. and has FPU, so
> I don't think I need those other versions.
>> If your target (sparc) tools are being built as multilib then check if
>> the library for your specific variant is being built. If it does not
>> get built, the compiler will link the default library and not warn
>> you. This can result is strange problems due to different instructions.
> I have verified that use of the #include file and linking with -lstdc++
> don't cause the problem, it is when something from the library is used
> and part of it is actually pulled in that everything quits.  A single
> line like
> cout << "something";
> or
> vector<int> something;
> will do it.  By disassembling from the start point at 0x02000000, I see
> that pulling in the library radically changes the startup code, causing
> it to jump immediately to memory without valid instructions.
>> If the correct library is being linked, the other area of potential
>> trouble is the atomic lock type operations. You will find this code in
>> a file called 'atomicity.h' under the:
>>  $prefix/lib/gcc/<target stuff>/include/c++/<target>/bits
>> directory.
> There is no 'atomicity.h' file anywhere in any of my rtems-4.6.1,
> sis-3.0.5, or erc32 directories.
> All of the tools are sparc-rtems-<whatever> where whatever is gcc, gdb,
> ld, as, and so forth so this all seems to be a closed, self-contained
> system.  I wonder if libstdc++.a is just incomplete or unsupported?
>>  Chris Johns
> Thanks again,
> Courtney
