file system
Leon Pollak leonp at plris.com
Mon Feb 2 14:33:01 UTC 2004
On Monday 02 February 2004 10:07, D. Peter Siddons wrote:
> Hi all,
>     I have an RTEMS application which resides in flash memory, and
> expects to read a configuration file at startup. It currently does this
> via tftp from a networked server, which works fine. I'd really like to
> make this thing stand-alone, so ideally it would read this information
> from some kind of local filesystem. There is enough capacity in the
> on-board flash memory if I could set up a filesystem in there; even more
> so if it could be compressed. It need only be read-only. Has anyone else
> done something similar? I've seen all the postings re compact flash, but
> I don't think that is at all the same.
> Thanks,
> Pete.
I use micromonitor developed by Ed Sutter els at emailbox.hdtv.lucent.com -
agreat SW. It contains the TFS flash file system - very robust with many
features.
Consider it!
BR
Leon M.Pollak
leonp at plris dot com
