file system
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Mon Feb 2 15:14:52 UTC 2004
I'd like some details about Micromonitor too- we have a similar need
at the moment.
Thanks,
Gregm
Ed Sutter writes:
 > Pete,
 > I run RTEMS with MicroMonitor underneath.  Provides an immediate
 > flash file system (read/write) for RTEMS-based applications.
 > If you're able to shift to MicroMonitor as your bootloader,
 > let me know and I'll be glad to give you details.
 > Ed Sutter
 > "D. Peter Siddons" wrote:
 > > Hi all,
 > >     I have an RTEMS application which resides in flash memory, and
 > > expects to read a configuration file at startup. It currently does this
 > > via tftp from a networked server, which works fine. I'd really like to
 > > make this thing stand-alone, so ideally it would read this information
 > > from some kind of local filesystem. There is enough capacity in the
 > > on-board flash memory if I could set up a filesystem in there; even more
 > > so if it could be compressed. It need only be read-only. Has anyone else
 > > done something similar? I've seen all the postings re compact flash, but
 > > I don't think that is at all the same.
 > > Thanks,
 > > Pete.
 > > D. Peter Siddons
 > > Bldg. 725D, NSLS
 > > Brookhaven National Laboratory
 > > Upton, NY 11976
 > > USA.
 > > Email: siddons at bnl.gov
