file system
D. Peter Siddons siddons at bnl.gov
Mon Feb 2 10:26:45 UTC 2004
Hi Ed,
      Thanks for your response, also thanks to Leon Pollack for pointing
me towards MicrMonitor.
The target for my app is the Arcturus uCdimm-5272, which comes with its
own rather limited monitor. I had shied away from replacing this with
anything else. If nothing else there would be a learning curve plus the
odd unbootable card :). It's somehow attractive to just take the
commercial part as-delivered, program in the app and off you go. The
ideal scenario would then be to have my files tacked on to the bootable
RTEMS image and arrange so the app can read them (no writing or deleting
needed). I wonder if one could use the IMFS for this? The task would
then reduce to pre-formatting the info in the image to look like an IMFS
filesystem, wouldn't it? Or am I misunderstanding something?
Pete.
Ed Sutter wrote:
> Pete,
> I run RTEMS with MicroMonitor underneath.  Provides an immediate
> flash file system (read/write) for RTEMS-based applications.
> If you're able to shift to MicroMonitor as your bootloader,
> let me know and I'll be glad to give you details.
> Ed Sutter
> "D. Peter Siddons" wrote:
>>Hi all,
>>    I have an RTEMS application which resides in flash memory, and
>>expects to read a configuration file at startup. It currently does this
>>via tftp from a networked server, which works fine. I'd really like to
>>make this thing stand-alone, so ideally it would read this information
>>from some kind of local filesystem. There is enough capacity in the
>>on-board flash memory if I could set up a filesystem in there; even more
>>so if it could be compressed. It need only be read-only. Has anyone else
>>done something similar? I've seen all the postings re compact flash, but
>>I don't think that is at all the same.
>>Thanks,
>>Pete.
>>D. Peter Siddons
>>Bldg. 725D, NSLS
>>Brookhaven National Laboratory
>>Upton, NY 11976
>>USA.
>>Email: siddons at bnl.gov
D. Peter Siddons
Bldg. 725D, NSLS
Upton, NY 11976
USA.
