file system
Ed Sutter els at emailbox.hdtv.lucent.com
Mon Feb 2 17:53:00 UTC 2004
Pete,
Can't help much here.  Haven't used IMFS.
I don't think you're misunderstanding anything.  It's more a matter
of comfort and need.  If what you already have "almost" works
and getting rid of the "almost" is less effort than transitioning
to uMon, then stick with what you have.
However, just so you know, I have a port to a SunDevil card which is
based on a 5272 (contributed by Bill Knight), so it's probably not
a big deal to transition that over to your card.  I don't have
this target myself, but I have no reason to think it doesn't
work fine.
Ed
"D. Peter Siddons" wrote:
> Hi Ed,
>       Thanks for your response, also thanks to Leon Pollack for pointing
> me towards MicrMonitor.
> The target for my app is the Arcturus uCdimm-5272, which comes with its
> own rather limited monitor. I had shied away from replacing this with
> anything else. If nothing else there would be a learning curve plus the
> odd unbootable card :). It's somehow attractive to just take the
> commercial part as-delivered, program in the app and off you go. The
> ideal scenario would then be to have my files tacked on to the bootable
> RTEMS image and arrange so the app can read them (no writing or deleting
> needed). I wonder if one could use the IMFS for this? The task would
> then reduce to pre-formatting the info in the image to look like an IMFS
> filesystem, wouldn't it? Or am I misunderstanding something?
> Pete.
> Ed Sutter wrote:
> > Pete,
> > I run RTEMS with MicroMonitor underneath.  Provides an immediate
> > flash file system (read/write) for RTEMS-based applications.
> > If you're able to shift to MicroMonitor as your bootloader,
> > let me know and I'll be glad to give you details.
> > Ed Sutter
> >>Hi all,
> >>    I have an RTEMS application which resides in flash memory, and
> >>expects to read a configuration file at startup. It currently does this
> >>via tftp from a networked server, which works fine. I'd really like to
> >>make this thing stand-alone, so ideally it would read this information
> >>from some kind of local filesystem. There is enough capacity in the
> >>on-board flash memory if I could set up a filesystem in there; even more
> >>so if it could be compressed. It need only be read-only. Has anyone else
> >>done something similar? I've seen all the postings re compact flash, but
> >>I don't think that is at all the same.
> >>Thanks,
> >>Pete.
> >>D. Peter Siddons
> >>Bldg. 725D, NSLS
> >>Brookhaven National Laboratory
> >>Upton, NY 11976
> >>USA.
> >>Email: siddons at bnl.gov
> D. Peter Siddons
> Bldg. 725D, NSLS
> Upton, NY 11976
> USA.
