GoAhead Webserver Configuration
Andrew Sinclair andrews at elprotech.com
Tue Feb 3 07:53:06 UTC 2004
How do I enable user management support in the GoAhead webserver without hardcoding the following lines into the source structure of RTEMS?
#define UEMF 1
#define USER_MANAGEMENT_SUPPORT 1
#define DIGEST_ACCESS_SUPPORT 1
It feels like I should be able to do this easily via the configure or make command whilst building RTEMS. Is this true?
Kind Regards
Andrew Sinclair
