raw_idt_notify on i386ex
Juergen Zeller
juergen.zeller at argovision.de
Thu Feb 5 06:47:20 UTC 2004
Hello all, please help, I get frustrated!
I'm not very experienced in BSP-porting and I have to run RTEM 4.6.0 on
a specific board with an intel i386ex, 512k flash, 1M Ram. I'm not able
to run the hello sample. The initialisation stops with the message
'raw_idt_notify has been called' after the _Context_Switch. The init -
task never gets reached.
When I try to run the ticker sample I also get the message
'raw_idt_notify has been called'. I read in the list that this should be
some interrupt problem but how can I figure it out? I changed the
console driver for simply polling data out via sio1, therefore the clock
driver should be the only interrupt source. A furher printk tells me
that my clock isr gets invoked. I figured out that the raw_idt_notify is
called by exception 6.
I thought the interrupt setting should be ok if my isr gets invoked? The
hello sample uses no clock driver. What goes wrong here?
regards
juergen
Jürgen Zeller
Entwicklung Software
TVI Lederer GmbH & Co KG
Industriestr. 4, 93161 Sinzing
Tel. 0941-3073761 - Fax 0941-3073737
